cold air intake E55 supercharged
hi all.
i am planning on building a cold air intake system similar to the one in the picture, only with aluminum wrapped in heat insulator and increasing the throttle body to 82mm from 74mm stock. air box too, i will have it built.
whats the best air filter i should use for highest performance? and where can i find the item.
i live in georgia, and i ll have to order it online.
and also, if i sacrifice the high beam lamps, will it give me noticeable difference in air flow now with the 82mm tb or is original intake enough?
thanks ...
