E-Class (W211) 2003-2009
e350 with multiple short to ground codes
Old Dec 30, 2014 | 10:23 AM
ilmf86's Avatar
e55 amg
I have a 07 e350. the car has multiple short to ground codes.
p2257 air pump short to ground
p0414 air pump switchover valve short to ground
p0057 heating component g3/5 left 02 short to ground
p0458 purge control valve short to ground
p0598 thermostat short to ground
p0448 charcoal canister short to ground
p2009 intake mani tumble flap short to ground
p0031 right o2 short to ground
p0051 left 02 short to ground
I already switched the entire engine wiring harness. checked all the obvious things..fuses, grounds, relays, fuse box connections, etc. I looked at every inch of both wiring harnesses new and old. I don't know what else to check. any help would be very appreciated
Old Dec 30, 2014 | 11:13 AM
ilmf86's Avatar
e55 amg
that is exactly what happened
Old Dec 30, 2014 | 01:12 PM
ilmf86's Avatar
e55 amg
the harness is not new. its off a junkyard motor that I put in the car. I put the original harness back on as well as the junkyard one.
the back story basically is I bought the car with a bad motor. put a motor in with no issues. starts right up. drives decent just has these cel's. original ecm.
Old Aug 19, 2023 | 08:58 PM
Eazzzy's Avatar
2008 Mercedes ml350
Short circuit to ground issues
I have the same issue with my 2008 Mercedes ml350 multiple short circuit to ground issues and no fuse are blown
Old Aug 19, 2023 | 09:00 PM
Eazzzy's Avatar
2008 Mercedes ml350
Anyone as a solution on how to fix this multiple short circuit to ground issues or know anyone with the same issues
Old Sep 12, 2023 | 06:16 PM
Jeffreyja's Avatar
2017 C300 Coupe
Hi everyone, please I need help with some issues on my 2017 c300.
I am currently having the following error codes all at once.
P059800 The coolant thermostat has a short circuit to ground
P1D01111 The crankcase vent has a short circuit to ground
P240B00 Actuation of the heater in the diagnostic module of the Evaporative Emission (EVAP) control system has a short circuit to ground
P240B00 The output for the switchover valve in the diagnostic module of the Evaporative Emission (EVAP) control system has a short circuit to ground
P260211 The output for the coolant circulation pump has a short circuit to ground
P003100 The output for the heater of the oxygen sensor 1 (cylinder bank 1) has a short circuit to ground
P024511 The low pressure turbocharger output has a short circuit to ground
P045800 The purge valve of the Evaporative Emission (EVAP) control system has a short circuit to ground
P003400 The output for the switchover valve of the charge air bypass flap has a short circuit to ground.
What could be causing this and has anyone experienced something similar?
My mechanic wants to replace my ECU
Old Sep 13, 2023 | 02:15 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Is your mechanic an MB specialist? From the description of the code, I assume they were obtained using an MB specific scanner.
Besides that list, which is long, did you get the current status for each code? Stored ? Current? or Stored and Current? Either the ECU is damaged, or there is a problem with the harness (cut and touching ground) between the ECU and the engine.
It is normal practice to delete ALL the codes, run the vehicle for a few minutes and rescan. Though most of those codes are static, I guess having the engine ON for a few minutes will be sufficient.
Old Sep 13, 2023 | 02:59 PM
Jeffreyja's Avatar
2017 C300 Coupe
Yes he knows his onions, the codes were also obtained using a MB specific scanner and are all current.
but replacing the ECU is a very expensive fix in my location. I just want to be sure the fault is from the ECU and not something else.
Old Sep 13, 2023 | 03:09 PM
JCM_MB's Avatar
To be honest, even in locations where the ECUs are more affordable, they are the last thing to change. I will need to be 1000% certain it is the ECU before ordering a new one.
Diagnosis takes time, and discipline --> $$. Way too many short to grounds. Therefore, I will be concerned about what triggered the initial failure regardless if the ECU is damaged or not. Let say it is the ECU, but no clue why. The new ECU is installed and seconds, minutes or days later is shorted again. What then?
First, you need to know what EXACTLY caused the failure, fix it, and repair/replace the ECU. Not the other way around
