E-Class (W211) 2003-2009
Draining front differential
Old Feb 6, 2015 | 09:59 PM
corkmb's Avatar
2008 e350 4matic
I am attempting to insert a small rubber tube into the front differential of my 08 4matic. I have the drain plug removed but am having a bit of an issue inserting the rubber hose into the differential unit.
Is there a trick to this procedure? One post mentions a rail by which one must insert the tube in order to access the sump of the differential.
I am scratching my head right now figuring out how to do a proper evac of the fluid in there.
I wonder why a drain plug was not machined in place. Sure would be easier😃
Thanks,
Turner
Old Feb 6, 2015 | 11:39 PM
konigstiger's Avatar
'71 Pinto
Try this http://www.google.com/url?sa=t&rct=j...,d.cWc&cad=rja
Old Feb 7, 2015 | 08:35 AM
corkmb's Avatar
2008 e350 4matic
Front Differential Drain
I tried the link-this link is for the transfer case. I am looking for some info on help with the draining of fluid from the front differential.
Thanks,
Turner
Old Feb 7, 2015 | 10:17 AM
'71 Pinto
So it is.
https://mbworld.org/forums/e-class-w...50-4matic.html
MB workshop recommendation, let oil escape for roughly 1 to 2 min http://www.google.com/url?sa=t&rct=j...tLQi2g&cad=rja
