E-Class (W211) 2003-2009
E320 D cdi avant 2005, driver mirror fault.
Old Feb 7, 2015 | 08:42 AM
Andy Wakefield's Avatar
E320 Avantgarde cdi
Exclamation E320 D cdi avant 2005, driver mirror fault.
Hello,
Can anybody help me, ive just noticed a ecu fault on my right hand side door mirror indicator bulbs. When the mirrors are folded in, the yellow lights work when you lock/unlock the car with no fault on the dash screen.As soon as they unfold and go into drive position it doe's not work and a fault comes up on the screen. Sometimes it works and the signal relay flash's at a normal speed. but when the fault is active the relay inside flash's fast. There is a intermittent fault on it,more than not it's in fault when unfolded. And
sometimes it clears itself. Can anyone shed a bit of light on this fault and a remedy please.
Thank you.
Old Feb 7, 2015 | 11:13 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W211 forum...
it's prolly the wiring...
Old Feb 7, 2015 | 02:36 PM
konigstiger's Avatar
'71 Pinto
To identify possible wiring malfunction https://mbworld.org/forums/w211-amg/...orite-mod.html
