Rear main seal & Transfer case leak questions
Good afternoon,
Interested in an '06 E500 4Matic with 130K. After a test drive, I took it to the local MB dealer for an inspection and was told the transfer case and rear main seal was leaking.
Seller said the shop* he takes Euro cars to said "most of these(E500's? MB? Euro?) leak a little bit of oil and it's nothing to worry about."
This shop is a very reputable Mom & Pop Euro shop I've gone to for 10+ years with my VW. The local MB dealer on the other hand doesn't have the best reputation.
I didn't notice any oil or fluids under the car, even after it had been idling for 15 minutes.
Not being familiar w/ the MB world at all, I'm curious as to who to believe. Is this a common minor issue that's solved with a 1/2qt ever other month or cause for concern?
Thanks for your time,
Aaron
Aaron
Good afternoon,
Aaron
Aaron
My 2cents
Such fluid seepage is not uncommon; some do, some don't. Unless it's leaving a noticeable puddle on the garage floor on a daily basis, I would not worry about it. Gasket replacements can be very expensive.
relinuca
relinuca
General rule on drive line seals.
Dry is best, damp in no problem, wet is OK-so/s0, signs of dripping and time to replace.
The seal is keeping a very small amount of fluid in, so a few drips a day, in relative terms is a lot of fluid loss.
The seal is also keeping water and dirt out, so if fluid is coming out at a rate high enough to form a drip, it can be letting contaminants in.
Dealers will always flag damp seals as bad. (wouldn't you want them to on a PPI?)
You need to ask if it is damp, wet or dripping. (or look for yourself).
