E-Class (W211) 2003-2009
W211 Low Battery Warning -
Old Nov 14, 2023 | 02:53 PM
  #101
RxMB's Avatar
2005 E320 4MATIC
Originally Posted by PeterLech
the big red electrical warning came on saying something like Electrical Failure, Visit Workshop.). Turned off the car for a few minutes, turned it back on, and the light went out, and neither message has ever resurfaced
That's great but not going to answer anyone's questions if they have the same problem.
Old Nov 19, 2023 | 07:06 PM
  #102
ot1's Avatar
ot1
2006 E320 CDI
Likely its the AUX battery by the cabin filter causing the red warning.
Old Nov 20, 2023 | 12:54 AM
  #103
RxMB's Avatar
2005 E320 4MATIC
I was under the impression this would not cause the red warning as long as the main battery is within spec.
Old Nov 20, 2023 | 03:08 AM
  #104
ot1's Avatar
ot1
2006 E320 CDI
no nope nein…they are independent …the AUX battery is monitored separately, if the voltage at the battery terminals is over 12.2 vdc and you still have the red warning, there is a fuse hidden on the (+) wire about 3 inches down. If the red warning is intermittent then the AUX battery is shot.
Old Nov 20, 2023 | 06:39 AM
  #105
Guidetaf's Avatar
2006 E 350 4MATIC, 40k Miles
W211 Low Convience Light
I Beleive Its Fixed I Went Into THe Back End Of The Computer & The Citcuit WAs Set To On, Turned It Off & No More Low Convience Lights & No Low Battery & Car Starts Up 1st Try Thanks So Much
Old Nov 21, 2023 | 03:45 PM
  #106
RxMB's Avatar
2005 E320 4MATIC
Thanks. Learning very slowly here but learning none the less. I found that fuse, struggling to get it apart. There is a fuse inside that little plastic piece???
Old Nov 21, 2023 | 03:46 PM
  #107
RxMB's Avatar
2005 E320 4MATIC
I'm struggling with this. Is this real? Back end of the computer?
Old Nov 22, 2023 | 02:15 AM
  #108
RxMB's Avatar
2005 E320 4MATIC
It's not this is it?
Old Apr 10, 2024 | 11:29 AM
  #109
jbeech's Avatar
72 R107, 04 W463, 05 W211
I am back in this thread. 2005 W211 is draining battery quickly, matter of days. Cannot find the source. Thoughts?
Old Apr 15, 2024 | 12:21 PM
  #110
Guidetaf's Avatar
The Battery Is Probably Dead Go Into The Computer And Make Sure The Aux Is Set To Off
Old Apr 16, 2024 | 09:54 AM
  #111
PeterLech's Avatar
2006 E350
In my case, it was rain
water leak at the antenna wire grommet at the base of the back window that caused a short in some electrical module located there. It also illuminated the left side parking light and let water into the well on the left side of the trunk. Stopped when it dried out.
Old Apr 20, 2024 | 08:47 PM
  #112
jbeech's Avatar
Hi Guidetaf, wish this were the case. New batteries, both of them!
Only workaround for now is disconnect main battery when I park the car for more than a few days.
Old Apr 20, 2024 | 10:53 PM
  #113
PeterLech's Avatar
2006 E350
What about a battery tender. I have one permanently attached to the battery in the trunk, plug it in when parked.
