No air from vents after blower motor replacement?
I hope you might be able to help me with this since I've searched the forums and the googles and have yet to come up with some useful information.
Earlier today my blower motor finally gave up the ghost. after making some annoying grinding sounds, I turned off the AC so I could concentrate on an email I was working on. The blower never turned of its own accord again. After pulling the blower motor and applying a 12 volt current to it, it was still dead. upon turning the motor upside down, all the magic smoke that powered it dumped out and landed as dust on the counter.
I bought a new blower motor and replaced it, but when I buttoned everything back up, while I can hear the fan turning briskly as it should, I am not getting any air coming out of any of my vents. Is there some sort of reset procedure I should try?
Last winter I took the blower motor out and cleaned the contacts as they had been corroded. After that it worked like a champ so I'm not sure that I did the procedure wrong this time.
Any insight would be much appreciated.
Oh, I should note that I have a 2003 W211 with analog HVAC controls.
I'm at my wits end and even tried to take the car to the dealer but they won't see me until Wednesday.
was NOT the exact fit the site claimed it was. Number one, the housing was incompatible with the the car, so screws did not line up right. I was desparate to get back on the road, and having no moving air in your car in texas is almost worse than a bad AC compressor. at least with a bad compressor there is air moving instead of baking you.
so, I ended up doing a really ghetto retro fit putting the fan into the old behr housing. As part of the retrofit, I had to use the old connector from the bad blower motor, because the connection on the new blower motor to the regulator had the wrong gender. After I got everything wired up, the fan spun no problem, but there was no air movement. it turns out that on top of not being an exact fit, not having the right connector on the replacement fan, the fins actually are turned in opposite directions from the OEM, so air was not being directed anywhere. I pulled the fan back out and refit the connector so the brown and red wires were opposite from each other, reversing the spin of the fan, and now everything works again.
TL;DR - Autozone's replacement fan is not compatible, and the fins are pointed in the opposite direction from the original.
