brake disk Rotors SBC
I have read differing versions of SBC deactivation without SDS along with Rotor and brake pad replacement.
If a WIS could be posted would be great.
I would like to complete without error codes and having to clear and resets. If there is a Diy I did not locate thank you
![Bump](https://mbworld.org/forums/images/smilies/bump.gif)
Received 4,441 Likes
'71 Pinto
I did see a similiar doc but was unsure if updates and procedures had changed.
I can use this doc thank you.
I am changing the brake fluid also and the sds doc was engaging for sure on this.
I have read in thread where braking the pedal before turning the key but in this thread there is no mention of this. Not required perhaps . thanks.
Even the official MB video on how to do this (which is a work of absurdist theatre by the way) talks about keeping that fob somewhere very secure.
Me, I think doing this is dangerous as hell given the possibility that someone will screw up and open the door or press the fob. Then again, I like my fingers a lot. And not getting brake fluid sprayed in my face.
I know that most people will accomplish this just fine if they use the proper procedure (and I'm not saying that what was said above is the proper procedure, because it varies from the official MB workshop video). But for the few who get snagged because they or someone else inadvertently do something to make the car wake up (and there are many ways to do it), the downside is just horrible and tragic.
Just remember that there are a number of machines available to Indys that don't have the Star Diagnosis menu, but do have the ability to deactivate the brakes. To me, it's worth letting them do it, and it shouldn't be expensive because the job on this car is pretty easy.
Do you have a link to the official mb video which you referenced?
Some have had success with a MityVac and drawing out from the calipers. ? ?
E320
Brake disk Rotor SBC
FYI all... several years ago I invested a tool through strategic tools:
http://www.strategictq.com/Images_Co...Catalog_NA.pdf
This was the perfect tool with no issues and money well spent. Good luck.
There is good info here. thanks.
BTW which devices have you used from this Co
MBworld Guru
Akebono I have not installed on any vehicle to date and I am dealing with a carboned up rims from the flying dust
I use lacquer thinner to take it.
I cant see why a oem brake pad on the front and ceramic brake pad on the back wheels would have any negative effect.
E320
I purchased the Mercedes SBC Tool, item #30369400 in 2008 @ my first brake service for $300. The new version appear to include wider vehicle coverage.
So you can have your brakes done at a reasonable price at Pep Boys, which offers an Akebono Ultra Ceramic brake package. I see a lot of MB, BMW, Audi, etc. being worked on at my local Pep Boys, and that package may be one reason.
I see their still close to this price on amazon.
Does this tool clear the sbc "time for retirement" code or 30k cycles
In my market this Co does not exist , with the aftermarket tools available specializing is common
