E-Class (W211) 2003-2009
[QUESTION] Grease Leaking?
Old Apr 7, 2015 | 11:12 AM
astrobike's Avatar
2006 Mercedes E350 4Matic (W211.087)
Question [QUESTION] Grease Leaking?
I found a leakage in front passenger side wheel area. Please refer to the attached picture. You can see the leakage from the black rubber boot(?) on the center of the picture. I have couple of questions below;
- What are the name of this boot and function(s)?
- Is the repair for this leakage an easy Do-It-Yourself type job?
- If so, what parts and tools are required?
Thank you very much for your answers
Old Apr 7, 2015 | 01:33 PM
konigstiger's Avatar
'71 Pinto
Fluid is leaking from steering box assembly. MB provides repair kits for oil lines, and tie rod but not assembly you will need to replace - MB remanufactured part # 211460240088. Check your PM.
