E-Class (W211) 2003-2009
Static interference in COMMAND on w211 E550
Old Apr 7, 2015 | 11:22 PM
sneerz's Avatar
2008 E550
I have noticed that my E550 has a strong background static noise if I turn up the volume at all, and I can especially notice it if a song has a quiet part in it and it really gets on my nerves. I have the COMMAND unit in a 2008 model and I really don't know what to do. I also have the ipod connection in the glovebox. Is the only solution to fix this to get an aftermarket head unit or are there other options? I heard a ground loop isolator might work but I don't know where to begin.
Old Apr 8, 2015 | 12:03 AM
samaritrey's Avatar
Super Moderator
THE C350
Is the issue only on the ipod or on any audio source?
Old Apr 8, 2015 | 11:45 AM
konigstiger's Avatar
'71 Pinto
If heard across all sources (radio, etc.) may be Audio Gateway (amplifier) check connections & housing/bracket ground if fine, definitive diagnose have someone pull fault codes using MB DAS. If you replace amp, replacement may need coding to match MOST setup - part # should be either 2118704289 or 6989.
Membership FYI if static coincides with rear defogger use, grid is damaged and rear window needs replacement.
http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
