Godhand lip to E63 front bumper question
I have a 63 bumper from Gary at Suvneer and just received their godhand cf lip and its nowhere close to fitting. Put it up to a factory E63 bumper and it fits perfect. Anybody else had this problem? Wrong lip from Suvneer?
I sent him an email already. A buddy stopped by that has one of Gary's bumpers and it fit perfectly onto his. Its the bottom side of the bumper that's wayyy off from the factory bumper. I know it'll get resolved. It just sucks having to have waited a few months to get it because of that damn port strike in CA and now find out that my bumper is different.
i don't have any right now but if you look at the bottom of the bumper below where the fogs are and follow the lower portion to where it comes up to the middle where it points that's where the issue lies. The space between where the bumper goes lower on each side is too small and if you follow the bottom of the bumper under the car the plastic doesn't continue on enough to be able to bolt the lip anywhere. there's no chance it could fit. My buddies front bumper was a perfect match and it was from Gary. The only difference was his has parktronic sensors and his also has the holes for the factory center grille clips. The one I have has tabs to screw the grille in or use the strange clips it came with.
14 550 sedan
I have Gary's 63 bumper too and used to have his godhand lip too. It did look a bit awkward when I first put it on but nothing a few more screws couldn't fix. I'm sure if you could get picture it'd be a lot easier to answer you.
