are my bushings bad"with video"
are these bushings shoot???.can it be that causes that i feel somethings move under the car??
i have changed the engine mounts, and the driveshaft center support
Lars
Lars
You must take the car to a shop that specilizes in,or has good equipment in frontend alignment!!----however, when you have a bad tooth, I guess you could pull it yourself!!
use a flashlight and look at the bushing, is it cracked or separated? replace in pairs. Be sure to check those ball joints too!!!! Good luck!!! Bushing tool part http://www.ebay.com/itm/like/311335106805?lpid=82&chn=ps
use a flashlight and look at the bushing, is it cracked or separated? replace in pairs. Be sure to check those ball joints too!!!! Good luck!!! Bushing tool part Mercedes Torque Strut Thrust Arm Bushing Tool Kit W171 W203 W209 W211 W215 | eBay
i have a regulary press, and i lathe, so i will tru to make my own pressing tools.is it hard to press the ball joints??
This is how it looked like, it has some cracks,is it a liquid bushing??
i have pressed out all the ball links and other bushing,with pressing parts that i made in my lathe,if somebody want pictures of them, i can upload it
Lars
Lars
