E-Class (W211) 2003-2009
ESP Inoperative message
Old May 16, 2015 | 11:56 AM
dpallone's Avatar
2020 GLE350, 2019 E450 Wagon, 2018 E400 Cabriolet
I have an 08 E350 4matic wagon with 85K miles. The ESP inoperative message appears consistently after the car has been idling for more than 3 minutes. Restarting the car eliminates the message. Anyone ever see this before or have a clue of what is going on before I take it to my mechanic?
Old May 17, 2015 | 01:01 PM
MoarPOWA's Avatar
2009 E550
I haven't this problem personally, but from what I've read around here, it seems like you may have a steering angle sensor fault. Does your cruise control also not work?
Read around the forums for steering angle sensor and see if it sounds like the problem you're having.
Old May 18, 2015 | 12:48 AM
dpallone's Avatar
Yes, the cruise control does not work when the message is displayed.
Old May 18, 2015 | 01:30 PM
jimbo1763's Avatar
2007 E350 Sedan
If the steering angle sensor needs to be reset, try turning the wheel hard over to hard over and then back to the middle.
I ultimately had my sensor replaced, and then some time later the light came on again. I took it back, expecting a bad replacement part, but found that this time it was the infamous brake stop light switch-that surprised me.
https://mbworld.org/forums/e-class-w...-easy-diy.html
Old May 19, 2015 | 10:03 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
+1 on Plutoe's comment. The W210 has 50 diagnostic fault codes for the ESP. I haven't counted the number on the W211 but assume it is similar.
Run the diagnostic test with proper equipment.
But please update the results here.
Old May 21, 2015 | 07:24 PM
westcott's Avatar
2008 Mercedes Benz E550 AMG Sport Package
I just replaced the steering angle sensor in my E550.
Fixed my problem but I did not replace it until my mechanic checked the trouble codes.
If it comes to that, I can walk you through it. I should have made a video but I had it out and in within 20 minutes.
