Rack and Pinion replaced, any other expensive repairs?
My SA said there were seals on the rack that were leaking and could not be replaced without removing the entire rack.
This service took me by surprise since most of the w211 owners on here dont mention having had this issue. Is it due to the insane winter on this side of the coast that are causing these seals to crack? My car has already been through 2 harsh winters under my ownership.
The rack and pinion service was also not part of the major service expenses on the w211 that I had researched which were:
Balance shaft issues for the M272 engine about $6k
Valve body and conductor plate issues, transmission rebuild about $3k-$6k
Airmatic issues about $2k (which do not apply to my E350)
Apart from these potential issues that I may run into, what other issues in excess of $2k can I expect? Or have you guys experienced? Im currently at 110k miles and my warranty is running out in 6k miles. I have already had my radiator seals replaced as I was leaking coolant into my transmission lines and that was about $1k
I hope im out of the conductor plate issues as I changed my pilot bushing a year ago and the car shifts perfectly, my VIN is subject to balance shaft issues but I understand that if the issue does occur, it will under 80k miles?
Steering racks are a rare issue on most cars I have been around and almost unheard of on Mercedes. I have heard of two in the w203 chassis and you are the second I have heard of on a w211.
Valve body is more common and since you mention it I assume you have an 2007? How long is your warranty?
The connector does leak but once you replace it you shouldn't have a leak anymore (upgraded o rings)
