Doors, keys, ignition HELP!!!☺️
My 2003 E320 keys have a flashing red light when I try to unlock the doors but they won't unlock unless I use the mechanical key. Once I get inside the alarm does not sound and I can't Turn the key in the ignition. What should I do?
Super Moderator
Flashing red light i believe means low battery but you can start your car with a dead or no key battery. You said keys so i assume you have used more than one with the same result?
If you can't turn the key in the ignition I would suspect EIS which means you need to visit a dealer or INDY with star.
