2007 e320 oil blow by help
2007 e320
Anyone know what the actual range is that the computer needs to see. All my resisters (I bought 50 for like $2) are reading slightly below 4700ohm. Can I just add a 100 ohm to it or can I put two in to read 9400?
Super Moderator
4.7K ohm resistor is what I used but can't remember what wattage it was. 1? I used it for about two weeks then bought a plug adapter so it was a little more protected and proper. (can't find a link but if you search you should be able to find it cost around $30)
http://www.jeepforum.com/forum/f67/c...istor-1380618/
