E-Class (W211) 2003-2009
How to remove sway bar on late W211?
Old 06-04-2015, 09:58 PM
ps2cho's Avatar
E
I am trying to remove the sway bar to do my lower control arms and I cannot see how it comes off because the top 6mm allen bolt points upwards towards the frame that holds the semicircular mount. I can't fit any allen key into the bolt!
Is there a special trick to this or something?
Old 06-05-2015, 12:39 AM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
I don't think it is an allen. It is a star. Torx type of bolt.
Old 06-05-2015, 01:04 PM
ps2cho's Avatar
E
On the rear side there are torx bolts..do these hold the entire bracket on and I have to remove this?
The 6mm Allen bolts hold the front half of the mount it seems.
Old 06-05-2015, 05:15 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Old 06-05-2015, 05:17 PM
cmriv's Avatar
Heat that bad boy up, those bolts have locktite on them i think. Could be mistaken but heat and lube always work.
Quick Reply: How to remove sway bar on late W211?
