what of these solenoids are the lock up solenoid?
I will try to change my lock up solenoid, cause my car is weird when its cold, its judder,like i am giving a little throttle,off and on..are there some other solenoids i should change while i have my gearbox open??
is it nr 35??
is it nr 35??
Aren't you putting the sled before the raindeer---typically most folks will have confirmed through testing that a solenoid needs to be replaced---another point why do you think a lock up solenoid has anything to do with your issue--put the aquavit down and think about it!!
i have read alot of folks with simular problems, and the last owner said that the workshop said that the solenoid was a problem.
i just need to try find the error,should i change more soilenoids while i have the gearbox open??
I dont have the money, but a friend have a spare gearbox..he said i can purchase them soilenoids cheap, so thats what i am thinking.
should i just change all the solenoids??
https://www.google.com/webhp?sourcei...cedes&tbm=shop
If you in fact have a .6 trans, I'd like to think you need a conductor plate. But plutoe is keeping it real with you, DIAGNOSE first!
thanks for answer, but i really dont have the money, so i need to gamble, the car have been diagnosed, but they did not find anything.
the car works perfect when its warm,its just a little slow on kick down, when its cold is jerking, and it feels like i am on and off on the throttle
so i will change the conductor plate, and the lock up solenoid
hope it will work,if somebody want to say something, it would been great
Lars
Lars
