Drift to right/Lowering/camber problem
Anyways, he said the only way to correct the camber is to remove the bolt on the lower control arm and slot the hole, move the bolt in the slotted hole out toward the tire, then tack weld the washer on the frame after the camber has been corrected. Is this the preferred method to do this? He swears hes done hundreds of BMW's this way and this is how everyone corrects this problem.
Any comments on this?
-Geoff
(BTW, when I lowered the car, i used 4 grade 8 1/4" washers on each front "L" bracket, and slotted the rear holes for the rear bracket. Total drop was about 1.75 inches.
can't you get a camber kit?
No, I didnt. What are you referring to when you are talking about a camber kit? The only way I can see to fix the camber would be some sort of coencentric bolt/washer that moves the lower a-arm out farther. Who makes the kit you are referring to?
