E-Class (W211) 2003-2009
Upper ball joint
Old Jul 9, 2015 | 04:37 PM
Lil754boy's Avatar
E500
Upper ball joint
I install Arnott airbag and losen the upper control arm @ balljoint. Now I am trying to tighten control arm and the the whole thing is turning. Is this normal? Does this indicate the balljoint is bad? Is their a trick to tighten?
Old Jul 9, 2015 | 04:47 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
start the nut like 2 threads. use a impact. and pry down on the the upper control arm so there is actually some pre-load on the ball joint.
Old Jul 10, 2015 | 11:58 AM
ps2cho's Avatar
E
I ran into the same issue...it's tough because you have to apply pressure to the joint. If I remember right I used a jack under the lower ball joint to push up and then used a pair of lock pliers to hold the thread while I turned the nut enough to get it loose.
