E-Class (W211) 2003-2009
yours, too?? - analog speedometer is not in sync with the digital display
Old Feb 5, 2004 | 10:27 AM
Mortenstein's Avatar
E-220CDI, VW Multivan 2.5TDI
Thumbs down yours, too?? - analog speedometer is not in sync with the digital display
Hi,
my analog speedometer is not in sync with the digital display. The analog speedometer shows approx. 2-5 km/h less than the digital which is very annoying - especially when using cruise control or limiter.
What about yours? Is this "standard" at the W211?
Old Feb 5, 2004 | 10:30 AM
moa4r's Avatar
S4
I never noticed a difference, the two show the same speed
Old Feb 5, 2004 | 12:04 PM
norb's Avatar
2009 C63 AMG
Mine is exact.
Old Feb 5, 2004 | 01:10 PM
ilm's Avatar
ilm
2004 E320 / 2007 SL550 / 2008 GL450
Smile
just checked....mine is exact.
2004 E320
Old Feb 5, 2004 | 01:18 PM
lig's Avatar
lig
was '03 E320 - now - '04 S4
Mine is pretty much spot on. Maybe it's a kph/mph thing.
It seems like those of us with mph readings are o.k.
Old Feb 5, 2004 | 04:32 PM
Double Eagle's Avatar
2003 E-500
Mine both read the same, BUT if you don't look at the speedo straight you can see a 1-3 MPH difference. It's angle dependent on your eye position. Since 1 MPH is ~0.6KPH, I would expect you could see as much as a 5 KPH difference by moving your head around a bit.
Trust the analog reading. Mine is spot on with the radar units set up at different places to tell you your speed.
Old Feb 5, 2004 | 05:36 PM
rmeltz1's Avatar
E63 AMG
Same Here - It's off by a couple MPH
I have noticed a slight difference between the digital readout and the dial guage of approx. 2 MPH as well. I had hoped to use it as a defense in court if I ever get stopped for speeding. But alas, I am not certain how to explain away the additional 28 MPH to the judge.
Old Feb 5, 2004 | 07:07 PM
Thumbs up Re: Same Here - It's off by a couple MPH
Old Feb 6, 2004 | 11:06 AM
CaptMike's Avatar
2003 E320
Mine is the same
Old Feb 7, 2004 | 04:57 AM
abhansali's Avatar
mine is off by about 2-3 mph. Are you going to take it in for this?
Old Feb 9, 2004 | 04:01 PM
Cal's Avatar
Cal
2018 Porsche Macan, 2017 NSX, 2011 R350
Mine is exactly the same.
Old Feb 10, 2004 | 06:45 AM
FJPM's Avatar
2003 E 500 - Full option
Is your watch working OK ?
Mine was all time delayted and is pertubated all data from the culster (i did not check the digital speedometer) but average speed, average consumption were wrong.
It was solved by changing the whole cluster.
