Rear passenger window not working.
My 07 E350 rear passenger window stopped working. Won't roll down with the driver switch or the switch on the door. Any ideas what it could be? Are the windows all on the same fuse?
Received 4,435 Likes
'71 Pinto
Interior fuse box f21 is for right rear door control unit but this will control all door functions. “May” be regulator or motor.
http://workshop-manuals.com/mercedes...d_replacement/
http://workshop-manuals.com/mercedes...le/page_18657/
I usually leave all window 1 inch down during the hot day.
Only left rear window does not work when try to use recycle air button to close all window. I then try to use button on driver side to move up and down, it does not move at all.
After 1 hour driving 1 hour home and let the car park in the garage for about 30 min and try again using button on driver side and it works.
This happen couple times during the hot day and leave all window 1 inch down.
What would cause this?
