HELP! Instrument cluster
Please response.
I have the same problem likes you and I can not find that menu in DAS to solve the problem, Could you please advice me to fix it.
Problem SOLVED!
Just figure it out. It was a wrong programing of the ZGW (or CGW). The items that concerns to the transmition were wrongly coded, CONFORT transmition was existent when it should be INEXISTENT. Only AUTOMATIC TRANSMITION should be EXISTENT. After changed, the gear display pops up in the cluster (no need to reset KI). Somehow i must have changed the CGW coding the first time.
1999 Mercedes S500 Grand Edition
Selling my 1999 S500 Grand Edition. I have to sell it to fund my son going to London to train with West Ham United Academy team. I don't want to sell it though....
2007 Mercedes CLK63 AMG
I've been breaking my head to find this feature on the IC for the W164 but to no avail.
The instantaneous consumption (mpg)!
My friend's 2011 ML350 has it while my 2009 does not. I have DAS Developer and have been poking around without any success.
I was looking at settings in the Reiserechner Block 1, 2, 3 and alles for the differences between his and mine but don't know what each of those entails.
Any hints?
Any hints?
Any hints?
Any hints?
Thank you for confirming. The other thing that bugs me is the position related tire pressures. I can get it to show up fine for a few hours, but after a cold start it will be substituted by the TPMS active message.
Can the firmware be updated via DAS?
#33
@angelovAlex: Where did you get the list of PIDS?
I'm looking for one for W245, since my S211 has been scrapped. I suspect a lot of the PIDs are common, but it'd be nice to be sure.
#34
Hi
The PID's are from a tool called XSMonitor, shipped with older versions of Xentry.
I have a PID file for the W245, I can decode that if you want me to.
BTW, I do speak to Alex. He is no longer an active member of the forum, but still works on the W211 platform.
I work on the W203 platform and have found quite a lot of interesting data.
I have some decoded PID files for both CAN B and C on the W211 and W203 platfrms. See here
#35
#36
Here you go! Unfortunately I only have the CAN C data (Couldn't find the file for your cars interior can, but hopefully this helps!
See attached file.
See attached file.
#39
Hi,
yesterday when trying to add fuel tank info to cluster (witch i did) some how i lost the automatic gear box shift info on both sides of Km info in bottom of the cluster. How can i get it back? Please help. I've tried several kinds of coding but none where successful. Thanks
EDIT: forgot to say that i have a w211 2004 car
#41
Hello Pedroenf,
Thank God you found the solution, I am battling with the same issue for one year now,
I know this is an old thread but can you pls help me with the tools and solution used in solving your problem.
I am a newbie myself.
#42
Hey guys. I’m all need to Mercedes snd their systems. I’ve just bought a C63S AMG and want to know if there is an equivalent to the Audi/VW VCDS Rosstec HEX2 that we use to modify our cars.
thanks again.
thanks again.
#43
#44
I did start my own thread under W205 C63S section but looks like no one really understands what I’m talking about.
#46
Your question is crystal clear but you’re spamming the wrong thread with this question. The answer is so simple and just a quick google search away that it really doesn’t need its own thread.
#47
If any of you folks are planning to be at Black Hat/DEF CON Car Hacking Village/BSides LV this year, I'd love to find an opportunity to get together for a drink or cigar or something. This thread has warmed my heart.
Edit: This landed in the wrong thread. Apologies.
Last edited by pa28pilot; 07-26-2022 at 10:55 PM. Reason: Accidentally clicked on wrong thread
#48
By any chance could You provide more info about programming AMG MENU with CH341A mini programmer please ?
I ve connected it to eeprom AMTEL 24C16AN though can't make it to read the chip.
Lucas
Lucas
#49
I've tried a few yes. I spent a lot of time translating all the options in development. I found that one too, the only one apparently related to gear box display. I'll try latter on tonight again. Here is the translation (google one)
aus - out
ein - on
manuell - manually
nicht erlaubt - not allowed
nicht - not
erlaubt - allowed
alt - old
nachleuchtzeit innenlicht - Interior light afterglow
scheinwerferaufschaltung - headlight intrusion
tagfahrlicht - daytime running lights
einheit wegstrecke - unit distance
einheit aussentemperatur - unit outside temperature
automatische turverriegelung - automatic door locks
auswahl anzeige in statuszeile - Select display in status bar
Vmax-begrenzung(winterreifen) - Vmax limit (winter tires)
sprache - language
audiomodus - audio mode
anhängerverlustwarnung - Trailer Grain Loss Warning
spiegeleinstellung - mirror adjustment
umschaltung 12/24 - switching 12/24
einstellung datum - setting date
umfeldbeleuchtung - ambient lighting
klimatisierung lenkrad - Cooling steering Wheel
druckeinheit - printing unit
fahrdynamischer seitenhalt fahrer - driving dynamics lateral support driver
ambientes licht - ambient lighting
taxi-dachzeichen - Taxi roof sign
fahrdynamischer seitenhalt beifahrer - driving dynamics lateral support passenger
taxi oder privat - taxi or private
schlüsselabhängigkeit - key dependence
spiegel anklappen - folding in mirror
heckdeckel - trunk lid
sommer/winterzeitumstellung autom - summer / winter time changeover Auto
abblendlicht - dimmed headlights
wegstrecke - distance
außentemperatureinheit - outside temperature unit
automatische türverriegelung - automatic door locks
anzeige in statuszeile - display in status bar
aussentemperatur - outside temperature
geschwindigkeit - speed
anzeig im grundbild - ad in the main screen
einstiegshilfe - access aid
zuheizer - heater
anzeige uhr - display clock
werkseinstellungen - default settings
komplette tankdatensätze - complete tank records
komplette texte für datenfunk - complete texts for radio data transmission
reiserechner - trip computer
variantencodierung menü-werkseinstellungen - variant coding menu factory settings
variantencodierung schlüsselkonfig - variant coding key config
manuell über konfigurationsmenu - manually via the configuration menu
heckdeckel öffnungsbegrenzung - boot lid opening restrictor
vorzeitiger abbruch gurtwarnung - Premature discontinuation seat belt warning
kein vorzeit. abbruch - no past. demolition
kein vorzeitig. abbruch - no Prematurely. demolition
vorzeitig. abbruch - prematurely. demolition
vorzeit. abbruch - prehistoric. demolition
gurtwarnung - Seat belt warning
ab motorstart - from engine start
nicht vorhanden - unavailable
vorhanden - available
bsg warnungen - bsg warnings
darstellung status zv-notöffnung - Display Status ZV emergency opening
aux bedienbarkeit bei KI15Raus - aux operability at KI15Raus
wecken über lenkradtasten - wake on steering wheel buttons
uk-variante - uk version
einheit tacho-skala - unit speedometer scale
vreg fahrerbedienung in statuszeile - VREG driver's operation in status bar
uhrsynchronisation mit HU - Clock synchronization with HU
außendisplay - external screen
sprachfunk - voice radio
möglich - possible
tankgeberfestsitzerkennung - Fuel sender fixed detection
tankgeberfestsitzerkennung mit x gebern - Fuel sender fixed detection donors with x
einstieg in service menü - entry into service menu
cancel-taste - cancel button
abhängig von eventmaske - depending on event mask
unabhängig von eventmaske - regardless of event mask
kontroll-lampe (nur bis vorserie) - indicator light (only up to pre-production)
anzahl tankgeber vorhanden - Number of fuel sender available
gurt - belt (cinto)
gurt akustik - belt acoustic
handbremse - and brake
lichtwarnung - light alarm
art-info bei lampentest - art-info at lamp test
gurtwarnung display - belt warning display
tempomat - cruise control
v-reg signale vom id 210 auswerten - evaluate v-reg signals from the ID 210
lichtwarnung autom. fahrlicht - light alarm Auto. Driving light
bremswarnung - breake warning
dämpfung bargraphen - bargraph damping
verdecksteuergerät - convertible top control unit
abbruch der schlüsselwarnung nach 30s - Demolition of the key warning after 30s
epc displaymeldung - epc display message
darstellung des hintergrundsymbols - Presentation of background symbols
klappbox warnungen - folding warnings
reifendrucküberwachung - tire pressure monitoring
vgl-displaywarnung - see display warning
vgl-lampe - see lamp
kurvenlicht warnung - headlights warning
datumsanzeige grundbildebene - date display basic image plane
bremsbelagverschleißwarnung - Brake pad wear warning
rußpartikelfilter warnung - particulate filter warning
vereinheitlichte ganganzeige - unified gear indicator
tachokennlinie - tacho characteristic
mobilitätskonto - mobility account
k-zahl - knumber
tachokennliniensymmetrie - tacho characteristic symmetry
symmetrisch - symmetric
unsymmetrisch - asymmetrically
rücksetzintervall - reset interval
eeprom-wert - eeprom value
darstellung geschw.-warnung - representation Velocity warning
tankinfo im reichweitenbild - tank info in Range image
menü RR: reichweite/tankinfo - Menu RR: Range / tank info
exception handler lampe - ExceptionHandler lamp
bild unterspannung - Picture undervoltage
bild überspannung - Picture Surge
wegstreckeeinheit für tachorückstellung - distance unit for tacho reset
verbrauchsanzeige km - consumption indicator
ölstandsanzeigen - oil level display
schalter - switch
fernlicht erlaubt - fernlicht allowed
kraftstoff filter warnung - fuel filter warning
reiserechner anzeige bei reserve mit - trip computer display with reserve with
strichen - painted
werten - cheap
wasser im kraftstoff warnung - water in fuel warning
KI ist programmiert, sommerausgabe - KI is programmed summer edition
einheit dtr-skala - unit DTR-scale
tankdeckelinfo - tank lid info
gwsz-vorstellung - gwsz concept
tankreservewarnung - fuel reserve warning
nicht definiert - not defined
serviceanzeige - service display
ölstandsanzeige - Oil level indicator
ölsensorwarnung - oil sensor warning
darstellung text aus eeprom - display text from EEPROM
elektrohydraulisch bremse - electro-hydraulic brake
wartungsrechner expertenmodus - maintenance computer expert mode
segmentring - segment ring
format datumsanzeige - format date display
wartungsrechner werkstattmodus - maintenance computer workshop mode
bedienhinweis fds - operating note fds
sollwert - setpoint
aus - out
ein - on
manuell - manually
nicht - not
erlaubt - allowed
alt - old
sprache - language
zuheizer - heater
möglich - possible
gurt - belt (cinto)
k-zahl - knumber
schalter - switch
strichen - painted
werten - cheap
sollwert - setpoint
After messing with any of these settings or resetting something in the developer mode, like one of the modules for ex: the instrument cluster. Would/could anything keep the car from starting? Still stuck with a crank no start situation. Any ideas would help. Thanks in advance
