E-Class (W211) 2003-2009
rear axle level sensor
Old Oct 8, 2015 | 03:55 PM
larsianer's Avatar
w211
see below
Old Oct 8, 2015 | 03:58 PM
larsianer's Avatar
w211
rear axle level sensor,where is it??
got a strange code.rear axle level sensor,i have air springs, and i dont know where that sensor is,someone here that can tell me, or give me a picture??
Old Oct 8, 2015 | 04:53 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Crawl underneath and look at the swaybar. The sensor is fastened to it.
Old Oct 13, 2015 | 11:40 AM
larsianer's Avatar
w211
there is nothing fastened to the sway bar, could it have fallen of,there is no mounting parts there either.and i cant fint any electrical plugs to it either
is it possible that i dont have that sensor,cause i only have air springs?
Attached Thumbnails rear axle level sensor-rear-axle-senosor-level.jpg   rear axle level sensor-rear-axle-senosor-level.jpg2.jpg
Old Oct 13, 2015 | 12:11 PM
konigstiger's Avatar
'71 Pinto
Like this...
Old Oct 15, 2015 | 10:48 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
That sensor is deff somewhere back there. It's the only way you received that fault code....
Old May 14, 2020 | 12:44 PM
charlesb2003's Avatar
2005 E320, 2008 E320 Bluetec
Does anyone know the part number for the linkage arm that connects the rear level sensor to the bracket on the swaybar? Mine keeps falling off because the rubber bushing that holds it on is wobbled out, and last time it happened I was on a road trip far from home. Not good to have your rear suspension drop while in the middle of nowhere. Thankfully I was able to reattach it to get home, but I don't want this happening again. 2005 E320 in case that matters. Thanks!
