E-Class (W211) 2003-2009
Visit workshop and noise from engine compartment..
Old Oct 13, 2015 | 01:10 PM
plasma's Avatar
2003 E320
I have a 2003 E320 for only a few months now. I've noticed that when I come to a stop then let off the brake, I hear what sounds like small motor running in the engine compartment. I also hear the same thing 'sometimes' when I unlock the car. This morning when unlocking, that noise lasted a lot longer. Then when I got into the car the "Visit Workshop" - battery light came on. So can anyone tell me what that noise could be and if it could be related to the "Visit Workshop" message. Also, is there a "workshop" that I actually can visit to see what's going on or is that some standard error message that MB throws out?
thanks..
Old Oct 13, 2015 | 03:16 PM
plasma's Avatar
2003 E320
Originally Posted by Plutoe
That's the default message, however workshop can be any shop that you know that understands the MB systems----sounds like you have a issue with your charging system---take care of the battery issue and then go back to the so called noise you think you are hearing!!
Forgot to add, I did replace the main battery a few weeks ago. That stopped all the consumer electronics messages.
I will test the smaller battery and see what it's voltage reads.
The noise sounds very mechanical and like it's part of the braking system.
Old Oct 13, 2015 | 03:40 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
SBC pump and or airmatic pump if you have a wagon with rear air bellows.
Old Oct 14, 2015 | 10:58 AM
plasma's Avatar
2003 E320
If the SBC pump is making noises, is that normal?
Old Oct 15, 2015 | 10:15 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Yes the SBC pump or airmatic pump makes a "sound" when you start the car, a noise is subjective and would be based on your knowledge of your car (unusual sound). Without details (metallic grind noise, whine, etc.) impossible to diagnosis in a forum
