E-Class (W211) 2003-2009
Rear sunshade
Old Oct 27, 2015 | 10:28 AM
chris1978's Avatar
05 mercedes e320 cdi
Rear sunshade
He is one for the gurus on here. 06 e320 cdi with rear sunshade. The sunshade does not move. I removed said shade from the car( surprising not as bad as I read) and tested it with a battery. The shade worked fine up and down. Checked the fuses that I could find that the shade was on and they were fine. I proceeded to order a replacement switch assembly. I swapped out the entire assembly but still didnt work. When I press the button there is no sound at all. Anyone have any ideas. There is a plug in the assembly that is not plugged in but there is no other wiring harness for it to go so I assume it is there for a potential option. sorta stumped here.
Old Oct 27, 2015 | 08:23 PM
chris1978's Avatar
Hi Plutoe, No I was unaware of this relay. What is the "sam"? This has to be the issue because I can't imagine what else it could be. Can you help me out in locating this relay? Is it on the map that comes in the fusebox? Is it numbered? Thanks bud
Chris
Old Oct 28, 2015 | 10:14 AM
hangit06's Avatar
2006 E320 CDI
Hope this helps locating the rear SAM.
http://bayhas.com/mercedes/w211/cont...ct_comploc.htm
Old Oct 28, 2015 | 11:22 AM
chris1978's Avatar
Got it, I will check it out. Thanks so much.
Old Oct 28, 2015 | 11:41 AM
chris1978's Avatar
Okay, which relay is it? I found a diagram list of these relays however none of them list/call any of those relays shade relay.
Old Oct 28, 2015 | 11:43 AM
chris1978's Avatar
Relays in trunk compartment
Relay
Despcription Relay 1 kA Fuel Pump Relay 2 kB Relay 2 Circuit 15R Relay 3 kC Reserve 2 Relay 4 kD Rear Wiper Relay 5 kE Rear Window Defroster Relay 6 kF Relay Circuit 15R Relay 7 kG Fuel Filler Cap Polarity Change 1 Relay Relay 8 kH Fuel Filler Cap Polarity Change 2 Relay
Old Oct 28, 2015 | 12:22 PM
hangit06's Avatar
2006 E320 CDI
Maybe this site will help with your search.
http://www.bbbind.com/free_tsb.html
John
Old Oct 28, 2015 | 05:52 PM
chris1978's Avatar
I give up, I guess I just won't have a rear shade. I can't find any mention of a sunshade relay. The only thing I can find is the fuses. Ugg! Thanks for the help guys.
Old Oct 28, 2015 | 09:22 PM
cetialpha5's Avatar
Mine is flaky sometime too. I think you really need a Star system to figure out exactly what is going on, but I've noticed that if I normalize things by opening/closing the sunroof and holding it down for a bit and the same with all the windows, it will start working again.
Old Oct 29, 2015 | 08:57 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
I can't believe people actually use the rear sunshade-to each their own. That thing creeps me out. Haven't used mine once since I bought my 211-no interest on finding out if it works or not hahaha
Old Oct 29, 2015 | 09:03 AM
SteveE400's Avatar
2015 E400 and 2015 GLK350
I use mine when I park at work. The afternoon sun burns down on the rear of the car, so the shade helps keep the (black) interior just a bit less toasty when I come out to go home.
Old Oct 29, 2015 | 10:18 AM
cmriv's Avatar
Understood. My fix to keeping things less toasty-window tint. No moving parts just BAMMM there-constant at all time hahaha
