flapping drive drive belt
When you take belt off, you can try 'off vehicle' method too.
Are you sure belt i routed right? Im not sure if all models can be routed wrong, but some can and I remember reading one case where belt was sliding heavily when it was not properly in its place.
There is no limit to stupidity.
"* Excessive movement or rocking of the tensioner pulley, or "belt flutter" when the engine is running. This means the spring inside the tensioner is weak and/or the bushing is worn. The tensioner needs to be replaced."
i will upload a new move with sound in an hour or so, the car works perfect now, its just this sound left, i hope its not the timing chain that i need to change,the km on the car is now 430,000
