E-Class (W211) 2003-2009
2003 E320 Service
Old Feb 18, 2004 | 02:29 PM
jmorgis's Avatar
2013 SLK
2003 E320 Service
Hello All, i have scheduled with MB the seat belt recall (I received a letter from MB USA)
Is there anything else they should check?
CD changer / Radio software update? etc
I dont have the NAV
Thanks for your reply
John
2003 E320 ~1500 Miles driven
Old Feb 18, 2004 | 03:46 PM
konigstiger's Avatar
'71 Pinto
SOFTWARE
Check for latest Audio gateway version
ENGINE
Bulletin P-B-07.00/28 – ECM
Bulletin S-B-54.21/101- ECM
Bulletin P-B-07.00/28e – ECM
BRAKES
Bulletin P-B-42.46/27A – Install pulsation damper for SBC
- Noisy brake pump
Bulletin P-B-42.10/33 – Replace brake disks
- Front wheel brake shutter during braking
WHEEL ALIGMENT & TIRE BALANCING
- Install camber/caster kits if vehicle drifts to either side
ENGINE TICKING
- Replace purge valve (part # 00-470-35-93) to fuel injection system
TRANSMISSION
- Replace electronic control module/unit if not shifting smoothly
WINDSHIELD WIPERS
- Replace if skipping or noisy
ENGINE COOOLING FAN
- Replace assembly if loud or vibration heard
Old Feb 19, 2004 | 03:14 PM
moa4r's Avatar
S4
Originally posted by konigstiger
SOFTWARE
ENGINE
BRAKES
- Noisy brake pump
ENGINE TICKING
TRANSMISSION
WINDSHIELD WIPERS
ENGINE COOOLING FAN
do you have info on the first three engine bulleteins?? thanks (great list of service bulleteins, btw
) did you get all of that done to yours??
Old Feb 19, 2004 | 04:53 PM
'71 Pinto
Originally posted by moa4r
:do you have info on the first three engine bulleteins?? btw did you get all of that done to yours??
P-B-07.00/28 – Lack of power full acceleration & mid range and hesitation caused by “two-footed” driver.
S-B-54.21/101 – (?) Dealer performed ECM (engine control module) update in checking for software updates on 12/3/03.
P-B-07.00/28e – Lack of power full acceleration and mid range and hesitation.
Had all but P-B-42.10/33 performed.
Old Feb 19, 2004 | 04:54 PM
'71 Pinto
Old Feb 19, 2004 | 09:19 PM
moa4r's Avatar
S4
thanks... so, you got the "camber-bolt" fix done for the pulling to the right issue?? How did that turn out? I had it done to mine, and am not pleased @ all w/the results, my steering now pulls to the left any suggestions?
Old Feb 19, 2004 | 11:20 PM
'71 Pinto
First I suggest you check the tire pressures all around and set to MBUSA recommended pressures. If this doesn't work return to your dealer and request a road test with their shop foreman. Unlikely, but if the shop foreman tells you that all is within spec and "normal", request that that the MBUSA area rep be brought in. By the way, mine worked just fine - first time around, perfectly straight.
Old Feb 20, 2004 | 08:48 AM
moa4r's Avatar
S4
thanks, i've checked the tires many times, and my service maanger told me he'd have someone take me out on a test drive, but I have been too busy to do this, they really should've gotten it right the first time
Old Mar 2, 2004 | 04:58 PM
Char03's Avatar
2002 S430
I was just told that since my car has over 12,000 miles, replacing the brake rotors falls under the responsibility of the owner. Can anyone confirm this? Even though this is a service bulletin because my wheel vibrates and the rotors need to get replaced.
