E-Class (W211) 2003-2009
Unlock range reduced - NOT a battery issue.
Old Dec 9, 2015 | 01:19 PM
marc hanna's Avatar
2023 GLK250, 1987 560SL
Hi all,
I've got a 2005 E320 Estate and just recently the unlocking/locking range has reduced to a few inches, meaning that I have to have the key right up close to the sensor on the driver door handle. This happened simultaneously with both keys, but in the spirit of ruling out coincidences I replaced the batteries to confirm and the issue remained unresolved.
This suggests to me that the issue is with the receiver/antenna in the car.
There are no issues with starting the car, and no warnings about convenience features being disabled.
Thoughts? Comments?
Thanks in advance
Old Dec 9, 2015 | 01:25 PM
marc hanna's Avatar
Slight amendment:
Since replacing the batteries, I can now unlock/lock from a range of ~25' but only when in direct line of sight with the driver door handle.
Old Dec 9, 2015 | 03:24 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I am not good with electronics and radio frequencies, but common forum knowledge is that those keys have dual transmitting.
The one for locks has high range and the one for windows/sunroof operation need to be very close to the car.
Sounds like your long range transmitting quit.
Good luck figuring it out.
Old Dec 9, 2015 | 03:36 PM
marc hanna's Avatar
That's my suspicion too. Is the central locking module and radio receiver all in one unit.
Old Dec 9, 2015 | 05:34 PM
marc hanna's Avatar
Yes I was aware of the dual signals. The symptoms indicate that the IR is working fine, I don't think this requires further explanation. It would appear to be an RF problem.
So the question remains, is the central locking module and radio receiver all in one unit?
Old Dec 9, 2015 | 06:47 PM
marc hanna's Avatar
Well, I didn't get any hits on the document, and the attachment is for an R-class, albeit many of the component locations would be the same.
Old Dec 9, 2015 | 06:51 PM
kajtek1's Avatar
Originally Posted by Plutoe
The attached, and your google search for document GF8020P2002GM plus your manual will answer any rational questions you can think of regarding your cars central locking system!!
Funny way of saying
"I have no clue"
Old Dec 9, 2015 | 06:57 PM
marc hanna's Avatar
Found this thread:
https://mbworld.org/forums/w211-amg/...s-popping.html
Old Dec 10, 2015 | 10:41 AM
marc hanna's Avatar
Well, I haven't been able to find any blown fuses, and the alarm siren works fine, so I don't think the issues encountered in the link in my prior post apply.
I think there is a good likelihood that my antenna module that has failed - having searched for this there is clearly a separate module from the central locking module. As it is a relatively inexpensive component, I'll just try swapping it out and see if that resolves the problem.
Old Dec 10, 2015 | 10:49 AM
kajtek1's Avatar
Did you try to search W210 topics? Those cars are very similar and when for some reasons not too many W211 owners research those cars, - W210 have very extensive database.
I found a topic about module on benzworld. IN STICKIES.
Old Dec 10, 2015 | 10:53 AM
marc hanna's Avatar
Yeah, I'm just sort of pecking away at it. I found the location of the antenna module. It's in the driver side rear pillar near the roof.
Old Jun 23, 2016 | 03:45 AM
yangchi's Avatar
E350 4matic wagon
Did you ever figure this out? I'm picking up a 2007 E350 Estate as well, which has similar issue. Now, I haven't gotten the car, so I don't know if it's the IR or the RF that's quitting. But owner complained about it sometimes not working, and told me battery is the issue - upon searches, I find the IR receiver maybe an issue, but then again, that would only impact convenience feature, not lock/unlock... so I'm guessing the RF would be it. Let me know if you have found a solution to this pls.
Thanks,
Old Jun 23, 2016 | 07:42 AM
marc hanna's Avatar
If it's the radio receiver/transmitter module in the car, be prepared to spend a few hundred dollars on repairing it. I think the module is about $350 and replacing it will take a solid two hours or more. So at the dealer, it's going to cost about $1,000. At an independent, maybe $600-$700.
