Battery warning light in cold weather
Have anyone of you experienced getting a red warning light in your display when starting your W211 in cold weather?
I received one today, the car had been standing still durring the weekend and it has been snow and upto -12c where I live.
Both the battery and alternator was new in May / June 2015, all the eletrical and convenience features are working fine and the car started without any problems.
Any help / tips are very appriciated.
Regards
NorwegianViking
On cold start after some sitting, the alternator might take a while to bring the voltage to proper level, so it could be normal, but this is good time to check alternator brushes. How many kilometers on them?
Also your car might have electric cabin heater, what puts big load on electrical system.
After a 20minute drive to work and restarting the car the error message disapeared, it also didn't comeback this morning. It seems the cold weather has reduced the voltage at start up and just needed some charging
Cold weather should not affect alternator output, while wear out brushes can act for long time before they finally die.
Better have them check.
It is probably is not the auxiliary battery, because that battery only charges for 10 minutes every time you start the car. So if you run all the way to work and all the way back and the car doesn't give you the battery light, it's probably not the aux. If you ever need a new auxiliary battery, this is an excellent one to get. The yeast ytx14bs at Amazon will give you high quality at a good price: http://www.amazon.com/gp/aw/d/B000WJX4BQ/ref=mp_s_a_1_1?qid=1453425146&sr=8-1&pi=SX200_QL40&keywords=ytx14bs&dpPl=1&dpID=51r3J G5reFL&ref=plSrch
