E500 Camshaft Options
The cams I found actually come with the rockers not the lifters. Can I reuse my old lifters just replacing the one bad one? Or do I need all new lifters?
I have no idea how the lifter collapsed. The engine was swapped into my car for me, when I got it back the new engine had a ticking noise coming from the drivers side rear valve cover. I drove it with the tick (I know I shouldn't have) but it is really annoying me now so I want to fix it.
Not sure about the slr cam over the e55. However i have a coworker that did the slr cams in his 55 so i would assume they are a tad bit more aggressive....
It is entirely possible there is another problem. The engine arrived to me with the tick so not sure what happened to the motor before the tick started. Also I send the car out to have the swap done since I did not have anywhere I could do it myself. I know the guy that did the swap had the engine apart a few times, it is possible something happened then as well. I put about 12,000 miles on the engine with the tick and it hasn't gotten any worse, doesn't seem to be causing problems. I just am sick of everyone staring at me at every red light thinking my car is about to die lol.
On a side note, I see you are in VA. I use to live in Tysons Corner, and then was in Herndon after I got the engine swapped. Now I am in NH though. I should have posted earlier and maybe you could have helped me diagnose the issue lol.
Yeah, a dyno sheet would be your best friend pertaining to the diff gains. Yeah i'm in nova and for sure would of assisted as much as possible. Hahahaha at you at red lights-chicks staring at you like
I did finally find some camshafts after months of looking that I had shipped from Belarus, those arrived a few weeks ago. I will be pulling the engine hopefully in a few weeks to do the cam swap, recleaning the oil passage and a few other things. I have a Mini that needs to go back together before I can start though.
Thanks for this info. Do you have or know who has the specs on the Kleeman cams? Trying to decide if they are worth the $$.
I had it done to mine, the 55 n/a cams are installed.
The car is working great and there is more power. The Engine Sound is more sporty and sounds completely different to the OEM 500. I love that mods really.
But I have to say, there was before the swap already a ECU and TCU Tune done from Seidt Performance from Stuttgart. So the gain would be more than on a OEM CLS 500 with 7G.
No Springs no lifter where changed, only the cams and some seals.
I used Victor Reinz Part number VS50442 when I swapped the lifter out, got them on amazon for about $30 for the set.
Yeah I am excited for the swap, that along with CAI, mechanical fan delete and finally fixing the lifter should make the engine a little more responsive and sporty.
