E-Class (W211) 2003-2009
camshaft position sensor voltage
Old Mar 3, 2016 | 01:10 AM
verlin samonte's Avatar
E200 2002 kompressor
Mine is a e200 w211 kompressor 2002 and it is throwing P0365 on the scanner.
I unplug the wire from sensor and read the connector voltage.
I put the key to ignition .
Read trigger pin and input voltage pin and i got 12v reading for both. Is this normal?
btw no check engine light but exhaust smell is bad, smells like unburnt gasoline.
