E-Class (W211) 2003-2009
sync date and time on dash and comand in 2006 e350
Old Mar 4, 2016 | 04:10 PM
yikes's Avatar
06 e350 17 glc300
last week i had to change the rear main battery in my 2006 e350 and now my dash and comand clock are reset to 1/x/2003 and the wrong time. if i go into the comand menu i cannot change the date and can only change the hour or the minute in 30 min increments. i read in another forum if i turn off the sync in the dash menu i can change the date and correct the time in the dash. this, i was able to do.
so now i have 2 different dates and times in my dash and comand unit
here is my problem....how do i get the comand to sync with the correct dash date and time. if i select sync in the dash menu after the correction....i end up getting comand time back which is wrong and have to start over correcting the time.
thanks in advance
Old Mar 7, 2016 | 08:11 PM
Blitz2639's Avatar
2008 E350, 2010 GL550
If your comand is set to the correct country and time zone the problem is that you're having GPS antenna issues as this is where it gets the time from.
Old Mar 12, 2016 | 01:07 PM
yikes's Avatar
06 e350 17 glc300
thanks very much for the reply....
I guess its not a good idea to set this time inside my garage
thanks again for the heads up
took the car out of the garage and within 30 mins the date and time in the comand was correct......set the dash back to sync and all back to how it should be
will
Old Mar 17, 2016 | 02:42 PM
starbrite's Avatar
2004 E320
.....and put the car back in the garage
