E-Class (W211) 2003-2009
abs inop?
Old Mar 10, 2016 | 12:46 AM
MBENZ_HENRY's Avatar
2008 MERCEDES-BENZ C350 SPORT, 1999 MERCEDES-BENZ C230 KOMPRESSOR
abs inop?
Hey guys I own a 03 E500 and today I finally had a chance to change out my upper and lower ball joints I read several posting's here and several other websites that advised removing the speed sensor to prevent damage once I got done I started the car and the abs inop light came on i'm trying to figure out what would cause this problem? on the back side of the spindle the sensor mounts up with a allen key how tight should this be? I didn't want to go too tight where it would damage the sensor or the plastic bracket some advice would be helpful thx
Old Mar 10, 2016 | 12:33 PM
I unbolted the allen bolt then I moved the plastic back cover out of the way I twisted the sensor while pulling it out so it would come out smoothly then I placed it up out of the way then reversed after I completed the replacement of the upper and lower ball joints the only thing I recall while doing to ball joints I turned the key to the run position to get a better angle with the ball joint press and when i reinstalled the sensor I cleaned all the dirt and grit off with a paper towel how tight does the sensor have to be? I backed of the bolt a lil bit because I didn't want to damage the sensor of plastic cover do I need to reset the sensor? let me know thx
Old Mar 10, 2016 | 03:01 PM
When I got the car back together the abs light and esp fault still remained on from last night through today would it help if I disconnected the battery for a short period of time will it delete the code for the abs and esp fault? how tight is the sensor supposed to be? i was trying not to tighten it too much to prevent breaking it
Old Mar 10, 2016 | 10:56 PM
Plutoe thx for the help I figured out after looking at the opposite side I mounted the sensor on top of the backing plate and it prevented it from going in the required distance and after I put it back together the right way there is no abs or esp faults I really appreciate the help and advice
Old Mar 20, 2016 | 10:45 AM
Biggame85's Avatar
2014 E550
Speed sensor
I have an 2004 e320 4matic w211. I recently had some trouble and diagnosed the problem to being my abs sensors. In trying to replace the rear sensors both were lodged in the housing and would not break free without breaking the sensor. So now both are still in the housing with virtually no easy way to get them out. Are there any recommendations for what I can do to get them out
Old Mar 20, 2016 | 08:07 PM
With the front sensors I twisted them a little and they came right out no problems. I could imagine if you live up north somewhere it could be a problem with all the rust thankfully I live in Texas maybe wd-40 could help pulling them out
