E-Class (W211) 2003-2009
E500 wagon power tailgate malfunction
Old Apr 28, 2016 | 02:34 PM
mattrox1221's Avatar
04 E500 Wagon
Hey guys, just purchased a gorgeous e500 wagon with only 39k miles and the only thing wrong is the automatic tailgate will not open. You can hear the motor running but nothing happens unless you open it slightly to help it out, then it will finish the job.
Any idea what the problem is? Anyone with simmilar problems, I was surprised when I searched And didn't find similar problems.
Thanks!
Old Apr 28, 2016 | 05:02 PM
samaritrey's Avatar
Super Moderator
THE C350
Sadly not many wagons in the USA and since most of the forum is US members not many posts about them.
Sounds like the transmission or whatever mechanism connects to the motor is bad.
Just looked up the closing mechanism https://www.parts.com/index.cfm?fuse...Benz-PUMP-ASSY
Looks like the motor #17 is connected directly to the arm so it looks like you have to replace it as one part. Or take it apart and see if you can fix it.
Old Apr 28, 2016 | 05:51 PM
agm18's Avatar
2006 4Matic wagon Elegance, Infiniti 2004 G35 Sport, 1969 Jaguar XKE (s) 1988 Camaro Convert (s)
Thanks!
Does it close when you push the red button? Does the lock engage and seal the door? If it does not do either the locking device will have to be replaced. This may be the cause of it not opening. As I recall it is about $200 for the mechanism. My car is 2006 4M wagon.
