E-Class (W211) 2003-2009
Doc for removing/installing turbo charger
Old May 26, 2016 | 10:57 AM
jwong's Avatar
07 E320 Bluetec, 09 GL 320 BlueTec
If you are going to work on the oil cooler seals or turbo charger on OM642 Engine this PDF document will help. It may save you some time... may be bumps/bruises as well
Old Jan 18, 2024 | 02:58 PM
jakubmomentum's Avatar
Sl550
Does the pdf give the torque spec for turbo install?
Old Nov 7, 2024 | 10:12 PM
bakhustud's Avatar
2008 Mercedes R320 cdi
2008 R320 cdi.
I replaced the turbo actuator but it's not moving.
Do I have to reprogram after installing a new actuator?
Do I have to position the arm up or down or a specific position?
I don' have a scan tool that can do that, just an OBD2 for simple stuff. I thought the actuator I ordered was faulty so I ordered another one, same problem. Won't go up or down, and car stays in limp mode.
Any thing I am missing?
