Someone with WIS can get me repair pdf?
Would anyone who has it working get me the repair instructions to replace both front axle half shafts on my 4matic including torque values?
2008 E350 4matic sedan. 211.087.
Would be a life saver! The boot just split and I need to get it off ASAP as its not drivable.
I did several boots replacement and did not worry about torquing.
The big nut can take over 1000 ft-lb and I don't think you have tools to over-torque it.
Than all the rest is 1 nut on the joint, that can take abuse as well.
Than would you do a search, you'd find my topic https://mbworld.org/forums/e-class-w...pictorial.html
I'm hoping I can get a local shop to inspect the joint and install a boot for me inexpensively if I provide them the axle to save me time and frustration.
Doing boots I did not need it, but have seen members putting muffler clamps on the joint and using slight hammers.
Make sure indy is equipped for the job and will not butcher it.
