E-Class (W211) 2003-2009
Digital Speedometer problem
Old Aug 10, 2016 | 09:39 AM
andykan's Avatar
W211 E240, W211 E280, W202 C240
I just noticed that my car have digital speedometer problem. I have a E280 Avantgarde Sport MY2006.
The digital speedometer show the wrong speed's units.
When set to km/h, it shows the mph value with km/h units. When set to mph, it shows the km/h value but with mph units.
Below is the picture sample of similar problem.
Can someone help to solve this problem. Thanks
Old Aug 10, 2016 | 10:23 AM
andykan's Avatar
Dear Plutoe, please be noticed that the digital display wrong show the wrong number.
1 mile = 1.6 km.
In the upper picture the digital number should be 18 mph and in the lower picture it should be 42 km/h
Old Aug 10, 2016 | 11:31 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Did you have car scanned for errors?
Seems both speedometers act.
At 1200 rpm once the dial shows 17 mph, the other time 26 mph. Was it on different gear?
Get GPS and compare to real speed.
Old Aug 10, 2016 | 12:15 PM
andykan's Avatar
Scanned and no fault. Different gear.
Without GPS its clear that the digital speedometer show the wrong value
Old Aug 10, 2016 | 01:42 PM
Honcho's Avatar
'03 SL55 AMG | 2021 AMG GLE 63s Coupe
An E280 you say?
Pics show an IC from an 8cyl AMG.
That seems strange to me... but what do I know... Are you sure that's the stock cluster?
Old Aug 10, 2016 | 01:52 PM
andykan's Avatar
The pictures are the example as I said. I have similar problem with those pictures
Old Aug 10, 2016 | 03:22 PM
kajtek1's Avatar
So this is not your actual problem on the pictures.
When you have 2 gauges showing different results, you need to get calibrated one to recheck.
Technically I would faster suspect the dial gauge to malfunction as it has mechanical motor that moves the needle.
Digital meter have less margin for error.
Old Apr 25, 2017 | 11:12 PM
Auto Arzt's Avatar
2003 W211 E320
To the original poster, I have the same exact problem. I like driving with the digital speedometer (speed in numbers) displayed on my instrument cluster so I know exactly how fast I'm going in mph. I live in California.
Drove to an indy mechanic to have my 2003 E320 version coded to accept the bluetooth puck with tail. Indy hooked up to the car with his computer, tried to do it but failed.
On the drive home I noticed my digital speed (in numbers) in mph was out of sync with the analog speedometer (needle), which is also in mph. Was driving 60 mph (needle) but digital speedometer (numbers) said I was doing 40 mph.
Bottom line, you will need to take your car to the dealer, or an indy who knows what they are doing, to have it corrected. Unless of course you have the Star diagnostics thingamajig lying around, then you can probably to do this yourself.
That said, I am still waiting for the mechanic to get back from his vacation so he can correct this heinous crime.
Hope this helps and good luck!
Old Nov 26, 2017 | 11:12 PM
jrsmith_68's Avatar
Veteran: Army
2007 C350 2015 ML400 1968 Ford Mustang
Did you get this corrected? What was the solution?
