E-Class (W211) 2003-2009
Front end clunk
Old Aug 14, 2016 | 06:25 PM
nivram13's Avatar
E240 -2003 E55 AMG -2005
Front end clunk
I've got this ongoing issue at low speed like backing out of drive I feel a clunk coming from front left side, when I turn the wheel hard to the left to park I can feel a hard clunk and sometimes a pop sound.
The lower ball joint and lower control arm has been replaced, I suspect the control arm is faulty despite being new, I've checked all other joints all is tight with nothing visibly worn. See video below when I turn the wheel left I can feel and hear the clunk I don't get this sound when I turn the wheel to the right.
Any ideas should I just pull the control arm and replace it with something better quality the one I installed was of eBay(German Parts Saver) and I suspect the quality is marginal.
See video below you can hear the clunking sound.
Any ideas?
Old Aug 17, 2016 | 04:58 PM
pinebaron's Avatar
07 E320 Bluetec
I had the same issue while going over bumps. Replacment of both front lower control arms did the trick.
Old Aug 18, 2016 | 01:08 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
Just looking at the middle ball joint on the control arm (where the sway bar link is connected to)... does that seem to come out more than it should? when turning left?
Old Sep 17, 2016 | 05:59 AM
nivram13's Avatar
RESLOVED
Turned out to be the control arm was junk despite being only a few months old. Avoid those cheap after market parts!
Old Sep 17, 2016 | 12:45 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Cheap aftermarket parts do have its place, but crucial suspension elements are not it.
I put cheap radiator hose on father's W124 as OEM cost close to $200 and it works for over 4 years so far.
But the car will not crash when hose blows. ....
Good to hear you've got it resolved.
Happy motoring
