E-Class (W211) 2003-2009
What width are you running up front?
Old Aug 30, 2016 | 10:52 PM
eatmydust's Avatar
2020 C43, 2008 E350
Hello All.
What width wheels are you all running up front?
I was looking at getting 18x9.5 all around, with an offset of 35. Will this work up front?
-D
Old Aug 30, 2016 | 11:27 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I run 9" with 235 tires and had good clearance, but too many variables to tell without actually putting them on.
Old Aug 30, 2016 | 11:31 PM
eatmydust's Avatar
2020 C43, 2008 E350
I feel like I will be in the clear but just hoping to have someone chime in on an opinion. Noticed you are a fellow Bay Area member.
Old Aug 31, 2016 | 02:51 PM
Pinoi Ryder's Avatar
2003 E500 Sport
i run 245-30-20 in the front..
also run 245-40-19 in the front
both are 9 inch wide
Old Aug 31, 2016 | 07:41 PM
pinebaron's Avatar
07 E320 Bluetec
19x8.5 front and 19x9.5 rears and no rubbing even with lowered suspension. Both front and rear tires are exactly the same diameter even though different sizes; you would want things to look even.
Old Aug 31, 2016 | 07:50 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
^sorry mate but what is OP supposed to look for in your sig?
Old Aug 31, 2016 | 08:04 PM
pinebaron's Avatar
07 E320 Bluetec
I'm so sorry; I corrected my message when I realized the information was not there.
Old Aug 31, 2016 | 08:10 PM
beejAMG's Avatar
all good mate.
Old Sep 1, 2016 | 08:18 PM
eatmydust's Avatar
2020 C43, 2008 E350
So I'm a little confused/nervous.
My stock was 18x9 Rear with an offset of 35
My stock was 18x8 Front with an offset of 35
My new wheels are 18x9.5 with an offset of 39.
Will this even work? I guess I need to learn more about offsets..
Old Sep 2, 2016 | 02:48 AM
kajtek1's Avatar
1" = 25.4 mm
Your front rims are 1.5"=38mm wider, what adds 19 mm on side.
Now you are increasing offset by 4 mm, so the rim center will be 4 mm closer to the car.
19+4=23 mm is how much closer the rim edge is going to be to suspension parts.
Don't think you have that much clearance.
Old Sep 2, 2016 | 01:18 PM
pinebaron's Avatar
07 E320 Bluetec
Perhaps not in context to your question but I stuck to 35mm offset though 'I feel' my rears could benefit with a deeper offset due to wider 275/30 tires; I have negative camber (with K-Mac bushings) to prevent tire rubbing on my lowered car.
Negative camber
Fronts: -2.68
Rears: -2.4
Old Sep 2, 2016 | 09:28 PM
eatmydust's Avatar
2020 C43, 2008 E350
Originally Posted by kajtek1
1" = 25.4 mm
I'm an idiot. I wrote the sizes down wrong.
I checked the manual in my car.
My front is 18x8.5 et38
My rear is 18x9 et38
My new wheels are
Front 18x9.5 et35
Rear 18x9.5 et35
So it seems the front will be 9mm closer to strut and 12 mm closer to fender. I'm not lowered yet so it may work..
Rear is 4mm closer to strut and 10mm closer to fender so that's in the clear.
I'm going to mount them most likely.
Old Sep 2, 2016 | 09:32 PM
eatmydust's Avatar
2020 C43, 2008 E350
My new wheels are
Front 18x9.5 et35
Rear 18x9.5 et35
I used willitfit website to calculate it out.
Old Sep 4, 2016 | 05:23 PM
2003 E500 Sport
My new wheels are
Front 18x9.5 et35
Rear 18x9.5 et35
any pics?
Old Sep 5, 2016 | 05:35 PM
eatmydust's Avatar
2020 C43, 2008 E350
Originally Posted by Pinoi Ryder
any pics?
My test tire comes in tomorrow, so I'll post a pic of the front tomorrow. Rest by friday
Old Sep 6, 2016 | 07:46 PM
eatmydust's Avatar
2020 C43, 2008 E350
any pics?
Front is in. Outer lip is fine. No rub on turns or during bumps. Very very close to suspension I'm spacing it 5mm more using spacer that's on its way.
Old Sep 6, 2016 | 10:29 PM
eatmydust's Avatar
2020 C43, 2008 E350
Up front:
18x9.5 offset 35
255/40/18 BFG GForce 2
Old Sep 6, 2016 | 10:41 PM
kajtek1's Avatar
That fender looks very close.
When distance to suspension arms will stay the same, the fender/tire might get closer when you make sharp U-turn on steep driveway
Old Sep 6, 2016 | 11:10 PM
eatmydust's Avatar
2020 C43, 2008 E350
Hmm maybe, but when I did a drive way test it did not touch fender, it also is still behind the fender, so it would tuck.
Considering seeing photos of these lowered w211 i don't think I will have a problem.
Moto on here runs 28mm 18x9.5 on a lowered car.
Old Sep 6, 2016 | 11:19 PM
kajtek1's Avatar
Owners do lot of different things with their cars, but that doesn't mean it is recommend to follow their ideas.
Old Sep 6, 2016 | 11:20 PM
eatmydust's Avatar
2020 C43, 2008 E350
Cool man.
Old Sep 21, 2016 | 08:44 PM
PHDZINE's Avatar
2007 e550
I have 20X10 +25 offset in the front with 255-30-20. I have the edges rolled to to make them flat. If you look at the edge of your front fender. They actually go inwards at the edge. I'll take a side shot when I have a chance.
