How to access 2004 E320 right high beam?
Thank you
Not trying to be a smartass here ... but the bulbs are more difficult to get to than should be the case, and the left is particularly challenging. The owner's manual tells you where the bulbs are and shows how to replace them, but it uses a picture of a headlight unit that is not installed in a car.
Suggestion ... once you get to the headlight bulb sockets, check to see if the insulation on the wires into the sockets is intact, or if it has turned to dust. MB used some uncommonly sorry wire on our lights. You may want to invest in a jar of Liquid Wire ... might as well coat the bare wires while you're down in there.
Good luck, Mate. This will be a learning experience.
I'd like to talk to the engineer that designed it.
Peter
I’ve got the old bulb out, and ready to put the new bulb in, but it doesn’t seem to want to go in all of the way. I can barely see it, let alone get my hand in there also. Changing a light bulb isn’t suppose to be this hard, is it ?
