E-Class (W211) 2003-2009
air spring
Old Nov 19, 2016 | 09:48 PM
alexqkama's Avatar
2006 C230 with 139k and 2005 C240 4matic
air spring
Visit workshop message is still showing after replacing the air spring. the pump makes noise when I open the door or using the fob to open it. The car start to lower a little bit and the stops. also when I get out of the car and lock it with the fob the car makes a bleeding sound.
Old Nov 20, 2016 | 10:52 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
http://www.ebay.com/itm/151604325097?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Nov 20, 2016 | 12:29 PM
ebenz123's Avatar
2006 E350
It's my understanding that you need to use a fancy scantool to fill the new air spring properly.
Old Nov 20, 2016 | 04:36 PM
kajtek1's Avatar
I think this is one of those myths that never got confirmed.
I played with my rear air a bit and per my experience the system runs self-diagnostics at each engine start.
Full airmatic is more complicated as it uses tank air on park car, but I would expect self-diagnostic runs the same routine
