E-Class (W211) 2003-2009
TeleAid Response Connecting...
Old Mar 29, 2004 | 10:48 AM
rmeltz1's Avatar
E63 AMG
Hi all - A second occurrence in the last year follows...
This morning I hit the wrench button to reach a technician. The call answers and I hear popping static sounds. The display indicates the call has 'connected'. But no voice. I try a second time. Same thing.
My third call attempt is made using the "i" button. Same thing. Finally, on attempt #4, my call goes through and I reach somebody.
I am subscribed to teleaid and what's more, this same non-response happened about 8 months ago when I had a flat tire.
I am curious to see if this problem lies in the 'electronics' of my 03. I thought my dealer got all the kinks out a year ago - after replacing a couple modules for the sound system and display...
(BTW - The reason I was calling was because my car's clock automatically adjusted itself an hour forward yesterday morning. And I don't even have the command system - which I was told would be the only way this could happen) LOL
If you subscribe to TeleAid, please be certain to give it a couple tests to ensure your connecting OK...
Old Mar 29, 2004 | 10:54 AM
Eddie Knopp's Avatar
2013 E 350, 2012 GLK 350, 2012 C300 4matic
In Europe they switched time this past weekend, maybe your car longs for Germany
Old Mar 29, 2004 | 11:05 AM
Fastbuck's Avatar
2019 Mercedes Benz S500L AMG Premium Plus
Re: TeleAid Response Connecting...
You may find it hard to believe, but you have to adjust the clock manually with COMAND.
Old Mar 29, 2004 | 04:29 PM
rmeltz1's Avatar
E63 AMG
You must be right! My car thinks it is still in Germany (so do I!) I wasn't aware time changed this past weekend there. I did have my display module replaced last year - perhaps this is the cause. If so, then the new module doesn't require command to update the time automatically. This is GOOD news as it means it is 'by design'.
Thanks for the response
Old Apr 1, 2004 | 12:08 PM
bmurphy's Avatar
I have attempted to use TeleAid on several occasions and I am able to connect about 50% of the time. I had my dealer inspect my unit and they indicate everything is OK. I believe the TeleAid device from Mercedes or their TeleAid network is just weak, especially compared to GM OnStar system. I will definitely not renew when my year is up.
2003 E500 Platinum Blue/Charcoal, E-2, E-3,
Wood Steering Wheel, CD changer, Chrome Rims
Old Apr 1, 2004 | 03:55 PM
Davel's Avatar
03 Eclass, 03 BMW 06 Porsche Cayman S, 03 Harley Davidson "bored & stroked"
I tried using mine last night, to try out the new feature of being able to schedule your next service appointment via tele-aid. It worked as advertised...
Old Apr 1, 2004 | 06:38 PM
marksatex's Avatar
04' E500 w/Appear. PKG, Panorama Roof
Have used mine several times for Tele_Track, hotel reservations, Vehicle questions- Always connects and always prompt
Old Apr 2, 2004 | 04:17 AM
Barry45RPM's Avatar
2015 ML 350
Response Time
I find that the call connection always goes through, however it takes MB personell a L O N G time to get talk to you. Disregard all the messages on the screen after you are told the call has been completed & just hold on... You are in a incoming calling que, and your call "...will be taken by the next available operator..."
The response by GM's Onst@r operators seems to be immediate when compared to MB's response time. but Onst@r is much more expensive. I don't know why all these car companies need to have redundant services anyway. I guess its the Betamax - VHS wars all over again.
