E-Class (W211) 2003-2009
p0365
Old Feb 10, 2017 | 09:26 AM
verlin samonte's Avatar
E200 2002 kompressor
p0365
im checking harness .
im following instruction on this link:
http://www.pelicanparts.com/techarti...or_Testing.htm
Mine is 211.042 271.941
I unplug the wire from sensor and read the connector voltage.
I put the key to ignition . Read trigger/signal pin and input voltage pin and i got 12v reading for both. Is this normal values for this engine?
Old Feb 16, 2017 | 11:46 AM
Originally Posted by Plutoe
Read the instructions again!!
the instruction is for e320 which has different engine than what i have.
is it also 5V for m271 engine for the signal pin?
