E-Class (W211) 2003-2009
Navigation Update Problem
Old Feb 26, 2017 | 05:47 PM
Stan Ball's Avatar
2005 E320CDI
2005 E320 CDI with factory installed Nav that has never been updated. Was told I needed Software service update disc installed before I could install NTG1 2016 Map disc. Purchased both discs. The service update disc shows 2 progress bars initially, top bar never advances more than 1/4 inch, and bottom bar never moves from half way across. Then screen goes blank soon followed by a map of Stuttgart Germany and surrounding cities. The NTG1 map disc will not load either, I assume because the service update disc would not load. I suspect a corrupted service update disc but would appreciate any advise as to what I should do now.
Old Feb 27, 2017 | 08:21 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W211 forum...
are you sure you have NTG1 COMAND?
Old Feb 27, 2017 | 03:51 PM
Stan Ball's Avatar
2005 E320CDI
NTG1 Command Version 2015 V15.0 is listed by Mercedes as latest update for 2005 E320CDI.
