E-Class (W211) 2003-2009
2008 E350 4matic Rear brake bleeder screw
Old Mar 4, 2017 | 11:53 AM
e350fourmatic's Avatar
2008 e350 4matic
Hey guys new to the forum and need help. I was goin to flush the brake fluid with motive brake bleeder. I can't find the bleeder screw on the passenger rear brake caliper. Is there a special location for this? I found the one in driver rear and the 2 fronts.
Thanks in advance
Old Mar 4, 2017 | 02:25 PM
konigstiger's Avatar
'71 Pinto
Should be there, see attachments for proper bleeding, actual caliper (part 0024202883) can be viewed here: https://www.tlsautorecycling.com/sea...50/194786.html
File Type: pdf
File Type: pdf
Old Mar 4, 2017 | 02:35 PM
2008 e350 4matic
It seems like the previous owner strip the bleeder valve on the passgenger rear😖
Old Mar 7, 2017 | 01:49 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Do you need a rear caliper or just the bleeder screw?
Old Mar 10, 2017 | 07:32 AM
2008 e350 4matic
Depeding if i can extract the screw.
