E-Class (W211) 2003-2009
Transmission replacement Concern
Old Mar 9, 2017 | 09:34 PM
SouthSideBenz's Avatar
2004 E500, 1997 C230
Hi all,
I am having an issue with my 2004 E500 with a 722.901 transmission. I was wondering If a replacement 722.907 would fit in my vehicle?
Mahalo,
Erik ml
Old Mar 10, 2017 | 01:32 PM
WDBUF70J14A423556. Im worried about the valve body too. I heard that I would have to take it to the mercedes dealership to flash. Would it be possible if I use my current valve body on a rebuilt 722.9?
Old Mar 11, 2017 | 04:16 AM
OnlyGerman's Avatar
Too many german broads
When my tranny went out the valve body was no good. The valve body from the replacement transmission could not be moved over. Had to pay for a new valve body with a used transmission.
Old Mar 11, 2017 | 05:12 PM
Originally Posted by Plutoe
Don't go BS on us---when you purchase a transmission it comes with conductor plate--forget about all the HS you read and forget about the bla bla.
Your VIN needs a 722.901 and that's it unless you want more problems---attached is a list of part numbers that were used with a 722.901--be watch full of spammers trying to sell you something that will not work or work with loads of money changing parts
Gotcha! thanks for your help I ordered a rebuilt 722.901 from a 06 S-class with a warranty. I'll try and stick with my current TCU and conductor plate as I think the issue was mainly a leak between the torque converter and bell housing, and some worn clutch bands. It was probably a stupid question to ask I just wanted to make sure I had the right version since a lot of transmissions for sale online were vague in the exact model number, most of them just say 722.9.
