2004 E320 SRS LIGHT -- Resistance Value too high! HELP
I have 2 SRS codes.
1) 9243 The Resistance Value in the ignition circuit containing component R12/10 (Front Passenger side airbag ignition squib) is TOO high
2) 92C3 The Resistance Value in the ignition circuit containing component R12/17 (Right front window airbag ignition squib is TOO high.
I went to the stealership and my service adivsor told me to just go to a Body shop and have them fix it since it most likely a wiring harness... I unplugged the yellow airbag connection cable and put it back in under the seat and reset the light, did nothing.
I can't figure out where the issue is or what I should do to trouble shoot it... Any suggestions? Anyone experience this before?
This should not be happening on a 1.5 month old car. Any thoughts or advice from the group would be appreciated.
