SBC battery
if I would like to remove the SBC battery to clean or check it, is it necessary to make a memory backup or something ???
or just remove and re install hte old or a new one ???
Any 14-BS type battery would work.
Mike T.
https://www.amazon.com/ACDelco-ATX14.../dp/B007IPKYXS
Mike T.
ok thanks
first I will remove it and test it,
than I would like to do a full clean up of hte drainage pipe under hte battery, because I have had water in it
then I will change if neccessary or put it back if it has normal parameters
thanks for the info, I was afraid to remove it without having a backup voltage connected
Also I swapped over to the 14 type/group battery for the upgrade compared to puny stock one.
