E-Class (W211) 2003-2009
Cleaning the crankshaft position sensor
Old Mar 27, 2017 | 07:34 AM
albania's Avatar
e220 cdi 2005
hello
I would like to clean the crankshaft position sensor, anyone has the instructions please ?
thanks
Old Mar 27, 2017 | 12:59 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Do you have any issue with it?
Being magnetic - CPS collects steel shavings on it, that can be wiped off with rag, but when you have lot of them, you have other problem.
Old Mar 27, 2017 | 02:43 PM
PelicanParts.com's Avatar
SPONSOR
Yes, are you having issues with it? If so, this article is for W211 E320, but maybe see if it may help you test yours: http://www.pelicanparts.com/techarti...or_Testing.htm
Old Mar 27, 2017 | 04:15 PM
albania's Avatar
e220 cdi 2005
no , I dont have any issue, at least seems so
I just wanted to make some routine services, I have plans to change the fluids, clean sensors, clean as many parts as I can, some myself, some at the mechanic
the car starts immediately, and seem to run good
so I will keep it like it is, hopefully it will be fine
thanks anyway
